1 - 3 of 3 Posts
Flat Broke
Anyone use the on standard V as an upgrade? They are supposed to fit destroyer but the plug is lower and doesn't allow retaining clip to work. I modified the fuel rail like someone on another thread did for some short injectors but for the life of me can't get this damn clip to work.
'04 1300
Unless you have a heavily built motor (big bore 1300 CC's or higher with head work and cams, or forced induction), you won't gain anything except headaches by swapping injectors.
Flat Broke
Only headache I had was getting them in since the plug was lower. I managed after a bit of modification and finesse. Changed injector size in map and bike runs great. Ran it though a couple time sessions with power vision as well. Thanks though.
1 - 3 of 3 Posts
