1 - 7 of 7 Posts
Kaboom
I am interested in this too........from what I understand, the "fall away" is the culprit of the infamous VRod "clunk." Right or wrong?
Go IRISH!
If you don't loosen the top triple tree clamps there will be a slight gap between the top triple tree and the adjusting nut - which in-turn would allow it to loosen again. You have to tighten the nut under the triple tree then the nut on top of the triple tree so it is a must to have the pinch bolts loose.
Dilligaf
You don't loosen the triple trees to check the fall away, but you will have to loosen to adjust the fall away.
Ron Cooper
Some one told me something about between the trees the pressure accumulated there would be like putting one hand on top of a beer can and one hand on the bottom and when you tighten the fall away nut it would be like applying pressure with your hands and squishing the can. Or something a long those lines.
06 VRSCR
Spaz - that's what I thought, but the service manual has you loosen the clamps just to check fall-away.
nd2 - thanks also for your explanation, and for everyone else's replies too!
Now I'm ready to tackle the 1000mi service checkup and save a couple hundred bucks.
jim
1 - 7 of 7 Posts
