21 - 24 of 24 Posts
What steps did you take to bypass the abs
Sorry for the excessively late replay. I ran all new brake lines. The old lines I removed and put plugs in the ABS module. I now have an ABS light that is on all the time, but it passes inspection and brakes much better. You can truly feel the difference.
The brake lines that I used were Venhill. It allowed some versatility, they had a tee for the front brakes that mounted nicely, and the customer service was great.
It's a common failure.I have seen it frequently,normaly on the front brake.You can bypassed the rear brake linking the two rear brake hoses with a brake line junction,
otherwise the rear brake will remain stiff.If you have skills and tools you can change the hydraulic unit by yourself,the only boring thing is the bleeding proccess,it will take you some time.
Hi, my 2013 muscle is suffering the similar issue with the rear brakes. What junction box will work for this?
21 - 24 of 24 Posts
