1 - 3 of 3 Posts
Will it work on 1inch bars with Harley channels?
Is it only a single cable setup? no sure how it works
Any advice greatfully accepted
Dual cables is mainly a safety (liability) issue - if your throttle body blades jam wide open, so bad that the spring won't return them, I doubt the second cable is gonna help much either.
However, for RACING - most rulemaking boards require the second throttle-shutdown cable be installed and operational.
My buddy that was helping me put my bars on wanted to run a single/internal cable, keeps trying to talk me into losing the second one.
I personally have no problem with them being there. And if you're going to run all the wires through also - you are going to (potentially) get into a space issue inside the bar also.
Rick
Hi... I'm Big Will
PM or email Buckeye826, he has an internal throttle set up on his bike that's pretty slick.
[email protected]
1 - 3 of 3 Posts
