1 - 20 of 167 Posts
· Moderator
OK, If I have heard the question once I have heard it a 1000 times. What exhaust is the exhaust for me. With that said, other than lining up a line of V-Rods with every kind of exhaust with every different kind of modification, there is not a better way to see and hear an exhaust than to see and hear it via a posted video. Now that the new format will allow us to post videos, it is time for all of us to pony up with these new digital cameras that take short videos and post them. I would like this thread to be a description of your exhaust and any mods to them if any and the posted video. Comments will be taken on likes and dislikes but the comments will be removed from time to time to keep this an exhaust video post only.
· Registered
SE V-Mod'd
I figured I better redeem myself after I posted that RC VRod snippet. :spank:
These are my SE's V-Mod'd. Maybe someone else has a better capture than mine... Sounds better in person of course.
BTW - if you use .WMV format, you can still get 16 bit (CD quality) with a slightly degraded video compression. Keeps the file size WAY down as you can see and still sounds the same as AVI or MPEG.
Leon
  • Image uploading. Refresh page to view
· Chad 02 V-ROD
Can I point out something
If every one could do the video outside so everyone can have a true idea of what they sound like thanks abunch
:wazzup: :plause:
· Metal Guitarist
Thanks for all the help Max, this is starting to get fun!
Mark please do! to boot that video was me running Val's leaned out map.
OK new one.
video captured with a Sony cybershot DSC-P32
This little camera can't get the best sound of these pipes, trust me.
OUTSIDE, not in a garage.
37 degrees outside
stock exhaust that have been v-modded
SE filter
this time completely topless
PCIIIR
now running map 809-020
· Registered
D and D 2 into 1
D&D 2-1 Full System
Stage1 Download
SE-Filter
Having trouble with the upload, does not seem to be working. Any thoughts Max? When I click Upload, I get a DNS type error. If anyone want to see this in the meantime, shoot me an email or private message.
http://www.v-rodforums.com/movies/d-d-2-1.mpg
Thanks Max for the URL
I will redo the video outside for this post and resubmit
· Color me Gone
D&D slip on mufflers on a dyno
Here is the D&D slip on mufflers on a dyno.
  • Like
Reactions: Victor_perez33
· SNAFU
Bart's Thunderheaders. Here is the MPEG video, a WMV video (unregistered converter ;) ) and a sampled WAV file.
· DeejRod!!
I have the V-Mods on my 2002 including the PCIIIr and high flow air filter...Enjoy!!
· Premium Member
After two days of learning, a couple frustrations, getting some help from Max, and trial and arror, I think I finally know how to upload videos to the site. Thanks for the help Max.
If it worked, below is a video clip of my Screamin Eagles Double Barrel exhust, with factory download and K&N Filter.
· Color me Gone
KeV-Rod said:
I can't play the Kaz clips.....
It seems that microsoft no longer supports the codecs for the camera that was used to record those clips. I took a few minutes and located the codec in an exe file if you want it.
It is a setup exe and then reboot and you should be able to watch it with windows media player.
1 - 20 of 167 Posts
