1 - 13 of 13 Posts
2010 VRSCF
My V&H slipon fell off! The left side fell the f**k off! Doing 70 on the interstate!
I assume that something came loose over time and it just went. I recovered the slip on however the passenger peg is gone. Does anyone know what pegs will mount up? Or do I need to find an OEM? I'm not sure of hardware that I may or may not be missing. Any help would be appreciated. Thanks in advance.
Look right on jpcycles. That’s where I bought my aftermarket pegs.
Will do. I'm gonna need the complete bracket. I found pegs but the brackets are a bit tougher I wonder if there's any other models that fit?
Bracket you will have to get from Harley if they even make it anymore or eBay or member on here. I have a set off mine but I’m not looking to get rid of them cause I want all my stock parts I had taken off. Not sure what models coincide with each other but check eBay or on here.
Those pictured are not for the Muscle (I believe). The Muscle has a bracket bolted to the frame held on by 3 Allen bolts and the slip-on section of the exhaust is connected to this bracket. Sounds like those bolts worked themselves out and then the slip-on eventually dropped off.
The front rubber mounting bracket could use a stainless washer and cotter pin.I don’t know why it doesn’t already have this.I’m talking about the pipe bracket.
1 - 13 of 13 Posts
