1 - 18 of 18 Posts
or something. I can't tell what's leaking but something is..... Any ideas? While I love the bike, I've never owned a bike with so many
issues. Yeah this is my first Harley......
Tie One On
Do NOT see the leak in the pics. Can you pin point the spot where the oil is ?
Sorry the top pic and it's in the shadow but the 5th/6th fin down on the rear. Oil is there. I wiped up but keeps showing up. I know they checked the valve lashing and said it was ok and that they put a gasket on when putting it back togehter. I just assume it's where the valves are. I never had any leaking before. It smells like oil. I wish I had better pics.
Tie One On
If that is the rear of the front cylinder, I am gonna guess the breather pipe under the lower section of the air cover is not in. Take the air cover off and look at the bottom to make sure the crank case breather is installed into the bottom cover of the air cleaner cover.
Also look for the O-ring at the end of that tube. It presses into a hole in the engine, on top of the front cylinder, on the left side of the head. This is a breather for the crankcase.
Discussion Starter #6
Will do and thanks.
There is also a breather hose on the rear cylinder to the air box lower half. It is under the plastic radiator resevoir, on the right side, almost under the frame rail. Make sure it is in the air box and the hose is clamped to the fitting comming out of the head. I use long flat nose pliers to grab the clamp and seal the hose on the fitting.
Wow my second post. I'm Helping!
Buy American!
You poor thing. You're hooked already.:grouphug
Discussion Starter #9
Cool. I appreciate it and will look at it tomorrow when I'm with the bike.
Oil what oil..... lol I used to have a shovel head with a 4 speed ratchet.... now that thing leaked.
Try to find the actual leak spot, if its the gasket bring it back and say hey you serviced it and now it leaks.
Tie One On
Because of the location of the oil I do not think that this breather is the cause, but a good assumption on your end that this may be it.
Dang Bob, 3 years and one tiny leak, I think you got a lemon. :D
Discussion Starter #13
Jim-
1) Coolant hose blew off while crossing from NY to PA - nearly stranded
2) Clutch fluids contaminated (and I had in the shop for normal servicing). Shop said they never saw that before. Caused popping out of gear - and in turns, one tends to freak out a bit.
3) Now leaking oil but I can't find the source. Under breather I noticed oil - wiped up. Did not see where it was coming from and all looks fine.
One issue a year.....I suppose it's not bad :)
Jim-
contaminated with what and how?
Discussion Starter #15
Dirt I was told. I suppose the paint coming off the reservoir should have been a clue. I was told if fluid is leaking out, moisture and dirt is coming in. I always had fluids replaced on a regular basis but also found out if you take the bike in for service, the shop only eyes the level and never really checked the clutch or brake fluids.
The master cylinder covers will leak if over tightened. DOT 4 likes to wick in and absorb moisture from the air. (I found out the hard way) Living and riding in the humid environment such as VA, you really need to be diligent with changing out your DOT 4 fluids on at least a semi-annual basis.
Discussion Starter #17
Yeah, that's pretty much what I've started doing. Once a year just doesn't cut it.
Discussion Starter #18
It's now more than a leak. Whatever is coming out is all over the left side. Screw it. I am dropping the bike off Saturday (at least that's the plan). Keep the bike and fix it. I have my car and too many deer are running around. My issue is the bike never leaked until after my 12k service.......
Bob
1 - 18 of 18 Posts
