no,only in the wide frames with 240.
the case is wider at the rear motor mounts
Not true, that distance is the same for all VRSC models (swingarm pivot components are the same).
The problem with a VRSCF engine being used in another model is the front exhaust port studs that are positioned for the left side exit. It also has the oil dip stick positioned in the right side clutch cover but that won't interfere with the swap.
Registered Useless
I'm running an '09 1250 motor in my '05B. Everything's identical except for the injector harness.
