1 - 7 of 7 Posts
I have an 07 vrscaw and I jsut drilled the exhaust to 8 7/16 holes per pipe which I read was OK without a new computer. I was just wondering how I would know if there was any lean running or worse engine damage happening. also can I go topless without a computer?
Not in EP anymore
No to topless without a computer or at least I wouldn't reccommend it..
Check your spark plugs for lean / rich type conditions
Jay Johnston
It won't matter in a couple of months anyway, the holes drilled in the pipes only whet the appetite for real sound. We all did it and most have already put some pipes on for real sound! Sorry for the bad news for your check book, but as soon as you hear a good set like VMods or CFR or anything else you will be pulling them off anyway.
Not in EP anymore
you're ok for now if you don't run topless
According to the V rod specalist shop here okay for topless but not for the pipes, but the recommend PC111 for best results and to be 100% safe.
1 - 7 of 7 Posts
