Does it run on both cyls or just one with that code?
Does it run on both cyls or just one with that code?hello, I have a problem with my 2002 Vrod: I have the engine light on with the code P0261 (fron injector open / low EFI). It comes back instantly as soon as I start the bike (even after a reset in the diag). I checked the wiring which is good, I changed the injector with a new injector and I still have the problem. can you help me. THANKS
Check all your related fuses for corrosion at the fuse box. Obviously enough voltage to make the injector work but some form of resistance dropping the voltage. Could also be related to that injector wiring. Compare voltage supply to the other injector. Check all grounds on the heads and bottom right of oil pan also while investigating. Might even be from a system relay issue. Voltage checks will track it down.Both cylinders seem to work normally but I have this code that appears even after a reset in the diag
ok thanksIf you have the ability, amperage draw will be a good indicator as well. While I don’t know the current draw off the top of my head, they should be relatively equal
I see this all the time with jets -
Your vehicle is a jet? You run around with the SES light on and you're ok with it?? I've seen this multiple times after a repair where the SES light refuses to reset, usually on GM's. Like you said, if it's ok it will eventually catch up and clear itself.I've had the SES light on in a vehicle that I replaced the all the fuel injectors on for hundreds of miles
Do you have a tuner like Cobra or any other that plugs into the injector plug on this bike?the bike runs well, it takes turns well, no misfires and stable idle!!! just this light and the fault code still present
Compare voltage at the system relay and each injector, key on in this pic. Should be identical.No, I don't have a tuner
