Had an issue with a shim being spit out under the cap. I was using Zippers springs retainers etc...I think a good product, it was my fault it happened (way over the RPM I should have been doing...anyway...), question; the heads are torqued but I need the specs for the cam retainer caps. Can anyone provide me with the torque specs for them. ( I should buy the manual and will later). Any help is greatly appreciated....
not sure but.....
If the cam journal caps are the same thing...85 in.lbs...
Discussion Starter #6
Thanks...everything worked out great...I know I should get the manual but with a websight like this who needs it. Thank you so much everyone....Blaise
