Can you disconnect the LEds that were installed?
Can you put your DVM between the positive cable and the battery terminal. In the old days (my 69 Camaro) I would use a small turn signal lamp between the Pos Battery Cable and the post. If it lit I knew I had an electrical issue. I would track it down by pulling 1 fuse at a time till the light went out. That at least isolated the circuit the problem was on.
