What do you think? I think it looks pretty good.
That is correctLooks good. My assumption is that when you shift one...the other shifter moves as well?
The Brake Can be done but it's a lot harder to have both work. Where this is just a easy linkage mod that works very well.I love this mod! is available for brake as well? Please some one send me more info!!
08 Night Rod
BOTH brakes should be used for stopping! The front has the most effect but should be balanced with the rear brake.I would keep both but i wouldnt do the brake cause you realy dont need to use the rear brake in a emergancy stop you shouldnt touch the rear brake anyway. All your stop power is from your front.
