1 - 16 of 16 Posts
so...i wanna slam some drag bars on my 04 A model.
what all do i need to get? i've done some searching and stuff, but i cant really seem to find what i need to know.
i want to get every thing all @ once, so what all do i need to buy?
the bars i know, obviously, but is there other stuff i need?
do they just slide through the gauge cluster/riser on there now?
if not, where can i buy different gaugeclusters/risers?
imma get the Arlen ness battasti(or however you spell it) oval grips, but thats all i really know.
thanks homies. :notworth:
REGUL8
Drag Bars You Say??
There is a million posts out ther for Drag Bar installation, custom fab and for sale. I would recommend HD drag and run the wires through the bars. I am no mechanic or mechanically inclined but that was the easiest install I have ever done, thanks to Max and the other forum contributors.
Later
Didnt moco discontinue there drag bars??
# 12/50 Ignite LE
Unfortunatley yes.
REVOLUTION !!!
Bro, just change out your riser to the B model and then you won't be limited to what bars you can put on. Just do a search on A to B Risers.
Friend of Max.
Rizoma. They're the best looking I've seen. IMVHO. :D
The Hawk
The A model V Rods take special bars that have a bracket welded on them to hold the cluster pod. The B models have a different setup that uses a clamp as part of the riser and you can use any bar that fits the clamp. The B is much more versital and cheaper to swap bars on.
Mike
B riser allows for cheaper and more range of bars..however B riser swapout can get expensive in itself...check Vmod for a B riser kit for approx 249 i think??..
cheapest route overal is the H-D drag bars...109 in H-D book...however they are discontinued...BUT,there are MANY dealers who still have these bars instock....I found myself a set and love them,as they are a nice compromise between FLAT bars like V-MOD sells for 249,and the stock pullback bars..they are 1 inch lower and 1 inch forward...
Vmod as I mentioned is next cheapest way to go...they carry two sets...first set is a flat drag bar,with mount tabs for stock clamshell....and another is 2" rise set...which should be similar to H-D drag bars....both are 249.
any other setup,rizoma,carlini or breathless...require other type of gauge holders...and are quite expensive....if money is no object..rizoma are awesome....or use a breathless airbox and use carlinis...many members here have done these bars and look amazing....
some people are on limited budget,such as me..LOL...Ill be going with H-D drags...i like alittle pullback,but not as much as stock...with forward controls a true flat drag bar will be fatigueing after several miles,as your lower back will be in a C position..
Dan
Mike
And I have a brand new 2007 B/D riser sitting in my garage collecting dust if you want it.
1 - 16 of 16 Posts
