1 - 7 of 7 Posts
Hey guys I got my bike all apart and want to remove the dogs ass and bag supports. I have searched for a how to do with no luck. I want to remove without damage to the parts. It seems there is no access to the mounting bolts with out drilling them out.
Thanks,
Mike
The Heavycycles Guy
take the fender off... 2 bolts on each side of the dog's ass, 10mm.
you'll need a die grinder, hack saw, or a Sawzall to "remove" the bag support tabs.
I just removed the same about one week ago. I recommend using a lift. Remove both seats and remove the rear fender and innder fender. The dogs a$$ is easily removable. One of the bolts for the luggage bracket is the top shock bolt. You must unbolt a plastic fender that is behind the gas tank and infront of the back tire to get to the second bolt. Once you remove both bolts, the bracket drops right off. It is harder than it appears to be.
Ok , so when the bike is raised, remove d.a. , then trim it, put in the Doc's led light ,
and replace d.a. ........
Any pics or advice ?
BobT
1 - 7 of 7 Posts
