1 - 3 of 3 Posts
How do you remove the dogass on an 07 DX? Does the rear fender need to be removed to get to the dogass brackets???
Thanks :notworth::notworth::notworth:
Simply remove the passenger pillion(2 nuts), You will see there is 6 or 7 bolts for the fender,remove them and disconnect the turn signal and rear stop/run light connectors.slide the fender up and back at the same time. once removed you will see there is a bracket 2 nuts attaching them on both sides.Might take a whole 10 min. to remove these parts. For sure get a manual...you will appreciate it!!
1 - 3 of 3 Posts
