Does your bike use oil?
  • No
    Votes: 584 79.8%
  • 1qt in 500 miles
    Votes: 18 2.5%
  • 1qt in 1k miles
    Votes: 60 8.2%
  • 1qt in 2k miles
    Votes: 34 4.6%
  • 1qt in 3k miles
    Votes: 36 4.9%
  • Total voters
    732
1 - 20 of 67 Posts
Does your bike use oil? If you answer yes do so by selecting the amount per 1k miles
No, not at all which is surprising!!
Ron Cooper
ha ha not unless the oil filter gasket lets go. I didn't use any oil before my oil blow out and I don't use any after. Now my fuel system thats another subject.
We Use Amsoil 20w50 ...not A Drop In Either Bike...just Changed Both Vrsc's....over 7000miles, Not Even Dirty
Non-erator
No, why, should I put some in??? It does seems a little squeaky at times. :)
When my bike was new it used some (@.5 QT/3000 mi). After about 6000 it never used a drop. When I put the 1250 Kit in, it has used @ .25 QT per 1500 miles, but seems to be leveling out. Just seems like the more time is on the motor the more the rings will seat up. IMHO don't think running the snot out of the motor will help seat them quicker, just takes some time and miles. When I did the tear down, I was shocked to see how well the sleeve looked. You could still see the original "FACTORY" hone marks like it was new. Never ever take a hone to these sleeves; they are done at the factory.
Hope this helps
Mike
RIDE SAFE!!
not a drop yet and it has 15k now
Carbon Yeti
None at all.
Jeff/Modistrator
oil usage
When I ran regular old HD20w50, my bike used about 1/2qt per 1500-2000 miles. I changed to Amsoil about 1500 miles ago and it hasnt used a drop since. I do run fairly hard at times. I have also noticed much smoother shifting since the Amsoil switch-over.
VRF0RUMS ORIGINAL
As per the other thread. NOPE, no measurable use since I have been using AMSOIL after the break in period. That was 3 years ago!:D
1st 6500 with HDSyn 1/2 q every 2K, swithched to Amsoil,last 7k have used 1q. I think that the size of the pan vs the dip stick config makes accurate checking of the 'level' quite difficult at best.
Friend of Max.
Mine drank oil like it was gas when I follwed the HD "reccommended break-in." After that, it found the powerband big time and the oil consumption stopped cold.
Ruthann's 2006 Nightrod got a pretty good break in on the ride home from the delaer and it hasn't used ANY oil.
Fine, it's a case study, and doesn't have any significant power to the sample number of 2 bikes, but it makes for interesting discussion.
1 - 20 of 67 Posts
