back story:
I've been around the block in the forum and doing a lot of reading.I have read the service manual but don't have a owners manual.
what i own:03 anniversary with V& H power-shots i'am the second owner.no other performance mods that I'am aware of.
bike run great lots of power and no hiccups through the power band.
I have looked high and low for any signs of a tuner none to be found.
I'am a noob to vrods but can swing a wrench,electronics are not my strong suit but I can follow instructions.
please advise
ISU
there is a HD flash that was discontinued in 08?ish. the flash was made for the SE pipes but the dealers used it as a cheap good enough way to make it not lean. the V&H may be close enough to the SE 16GA pipe that it will feel fine.
would this ever be an issue if the bike needed a re-flash,you said it was discontinued
ISU
no they can flash back to stock. the only reason they stopped using it is because they quit making the SE pipes for the V-rod
