Yeah I went and talked to them this morning and showed them the paper towel I put it on. They didn’t seem to concerned. I’m changing over to amsoil now and I’m actually going to change again in 1000 miles just to be safe. Metal particular scare me. But I’m probably being to cautious about it.
A healthy engine will produce x amount of fine metal in a given mileage interval. I seldom see more then half the magnet with a slight dust coating. First or second oil change when new, It had a small 1/16" dia ball stuck to it. That concerned me but in the last few years, nothing has changed. It also never burns oil and in 5k with Amsoil it never needs to be topped up. Mind you, I gave the rings a good workout on the trip home from the dealer to seat them in fast. Not high rpms but lots of repeated load cycles. These engines that are oil burners had a botched ring break in from driving them too easy at first without ring loading and it will take a shit load of miles to get them to seat in now.
If you are getting slivers on the plug, you have some form of issue. It may clear up with more miles as most do but if not, I'd be worried something is eating itself up. Cutting the filter apart is a better view of what's going on for debri and amounts.
We had a saying in aircraft that unless the particle is big enough to have it's own part number to not worry about it. This is not the case with these Revolution engines. Aircraft engines are pretty crude in comparison and make lots of metal but again, they have a normal amount too that's acceptable. Revolution, once broken in should only have light dust on the plug at oil change time or the odd small spec here and there.
