2003 V-Rod, CFR Headers, CFR Fueler, Oberon Slave, Chrome Forks, Chrome Sway, Chrome Calipers.
I bought a 2003 V-Rod from National Powersports in New Hampshire. When it arrived in Hayward CA I added the Smart Siren II and realized i needed to discover the code stored on my TSSM. Two months later, several fights with my exgirlfriend, 2 emotional breakdowns,16 45 cal. rounds thru my 1911 on some defenseless firewood(I had to break something)and I finally see the logic in how Harley has the programing set up. On,off,on,off,on,,Left turn twice,, Key fob twice quickly,, then a SINGLE left turn,, is the sequence for setting AND discovering your code.They dont tell you that anywhere. I never did learn my old code, and if you mess with it pushing the controls out of order it is possible to disable the system to where you no longer need the key fob to ride your bike(no turn signal pushing either) in order to reset my system I had to reprogram my key fob as if it were brand new. I had read that if you push the key fob numerous times AWAY from the vehicle it is possible that the fob will fall out of synchronization with the TSSM. well pushing it a bunch of times NEAR the vehicle is even worse. The important thing is you MUST learn your code while you have your fob in your possession, lose it with out knowing your code and you WILL be buying a new TSSM. Realizing that ruined the fun I should have been having as a new Harley Davidson owner.Now that I have that stupid (its really hard for me not to swear here) code I can enjoy how cool I look on my V-Rod. And I dont care how silly that sounds, I have had a very rough last two months
