Gasoline direct injection has been in production engines since the mid 1990's, first with Mitsubishi, but later with Nissan, Toyota and VW. Now pretty much every major manufacturer sells direct injection engines including GM. It is a proven and thoroughly reliable technology today. Interestingly AMC was fooling around with the idea in the 1970's but didn't have the technology back then to make it reliable.
Direct injection for automotive diesels had to wait for the development of piezoelectric injectors capable of operatiing at the much higher fuel pressures required for direct injection into a diesel engine. With gasoline direct injection, the injection even occurs during the intake stroke, so fuel pressure does not have to overcome combustion chamber pressure, although today there are piezoelectric gasoline injectors that can even add fuel during the combustion event if necessary for power.
With diesel direct injection, fuel in injected near the top of the compression stroke, when the intake air is compressed and hot, hot enough to burn diesel fuel. This requires pressures upwards of 22,000 psi (compared to the 30-35 psi of most gas common rail injection pressures). In heavy duty diesel engines up through the 1990's, these pressures were generated in the injector by a pushrod operated off the engine's camshaft, much like a valve. Fuel was metered to the injector, but it required mechanical force to generate the pressure necessary to atomize the fuel and overcome combustion chamber pressure.
Modern piezoelectric injectors can achieve these pressures electroncally, and with electronic engine management, permit more than one injection of fuel per combustion event, allowing the flame front to be very carefully managed to improve power and reduce noise and emissions.
These are very reliable systems. I don't understand where the stories of problems come from. I'm in the Audi Club, all modern Audi engines have direct injection and there are no problems associated with it. Dead reliable.
