1 - 10 of 10 Posts
Smokebomb King
I just did an install for one of my friends. I did the headlight mod (ballseye) and its too bright for him. Is there anyway to dim just a single led strip, maybe hard wire in a resistor or something like that to the positive lead going into that specific strip? Any info would be appreciated.
Lou
Thats exactly what you do. Just play around with different resistors to get the desired brightness.
:them: really is the only option since it's actually a diode. Less power=less bright
I'm no electrician but I'd put an ohm meter across the LED strand or whatever you have and go from there after seeing what kind of resistance the circuit has. Then go off percentages and such. That would make sense to me but then again may actually not help you whatsoever LOL
if you have an adjustable bench power supply, you can connect the LEDs to that and adjust the output of the power supply until you get the dimness you're seeking. RadioShack has some nice universal power supplies/adapters that would allow you to adjust in 3v increments.
Smokebomb King
Well i really don't need to dim the whole set up (i can already do that with the remote unit). Its just the one strip thats too bright. Don't really need a whole controller, i think the resistor is probably the best, cheapest way to go.
1 - 10 of 10 Posts
