1 - 13 of 13 Posts
What size is the '07 and newer rear drive belt??? What size is the '02 - '06 belt???? I want to say 1" and 1.5". Just looking at some pulley options for my Marchesini wheels. Thanks, Bryan
The '02-'05 (not sure about '06) are 14 mm pitch, 37 mm wide and either 149 or 150 teeth. I read somewhere on the forum that '07s have 151 teeth (swingarm is longer to fit the larger fuel tank) but can't confirm this and I'm not sure of the width.
Thanks. Anyone else :wazzup:
matt blk & fire hot
true, 151 tooth on '07 up confirmed with HD factory tech line, it is 14mm pitch on all vrods
true, and I thing the belt pitch went to 15mm too.
I'd be surprised if the pitch changed from 14 mm to 15 mm. It would be a major rework with no benefit (this would actually be detrimental to belt performance). I don't have a newer model handy to measure this so I'm not sure, but I'll check the next time I see one if I haven't heard from someone else before that.
Bone Stock B Model
Someone check there 08 parts manual and see if the part number of the front pulley is.
Not sure about actual dimensions but I do know the new ones are narrower and longer than the stocker, the new ones still aren't as narrow as the SE is and the SE is the same length as the stocker (mines an 05).
matt blk & fire hot
belt pitch? pulley pitch? what years?
I'll start a pulley list later, but I think the change was in '05 for wide tires? '07 & '08 should be the same, I have both parts books.
The pitch change was listed in the HD parts computer at the dealer.
un-confirmed list: confirmed with HD factory tech line, it is 14mm pitch on all vrods,
the 15mm in the parts computer is a glitch.
149tooth:
40627-06.....21mm................................14mm pitch
40118-05.....25mm.....'02-'06 vrsc...........14mm pitch
40105-04.....37mm.....'07 vrscr
150 tooth:
40658-06.....21mm...............................14mm pitch
40119-05.....25mm...............................14mm pitch
40027-01A....37mm.....'07 euro
151 tooth
40144-07.....25mm.....stock vrscdx '07.....14mm pitch
152 tooth
40145-07.....25mm.....'07 euro
2" of dangling death
they are the same 07-08, belt 40144-07, front pulley 28 tooth 40656-06a
matt blk & fire hot
14mm belt pitch on all vrods
I confirmed with HD factory tech line, it is a 14mm belt pitch on all v-rods, the parts notes are a glitch in the computer at the HD dealer and on the net.
matt blk & fire hot
drive belts / 26t
Belt drive info CORRECTIONS
149tooth: 28t/72t sprockets..14mm pitch..short swing arm..VRCS usa
40627-06....21mm=.827"
40118-05....25mm=1"
40105-04....37mm=1.4+"
40105-01....37mm=1.4+"(old number)
(Note: for usa 26t you'll need spacers on axel cams)
(Note: use for euro 26t with short s-arm)
150 tooth: 30tx72t sprockets..14mm pitch..short swing arm..VRSC USA 02'-03'/euro
40658-06.....21mm=.827"
40119-05.....25mm=1"
40027-01A...37mm=1.4+"....(VRod 02'-03')
40027-01.....37mm=1.4+"....(VRod 02'-03')(old number)
(Note: use for usa 26t with long s-arm)
151 tooth: 28t/72t sprockets..14mm pitch..long swing arm..VRSC usa
40144-07.....25mm=1".....240 tire vrscdx '07-up
(Note: use for euro 26t with long s-arm)
152 tooth: 30t/72t sprockets..14mm pitch..long swing arm..VRSC euro
40145-07.....25mm=1".....'07-up euro
Killer Service Inc.
TTT
Very good belt info.
Alot of talk about belts going around thought I would bring this back up
rsc
1 - 13 of 13 Posts
