1 - 20 of 86 Posts
Greg/Moderator
I installed the spacers and gaskets and it was worth a little over 3 hp on the local dyno. This was compared to my last run there, its not a happy dyno very close to Gail's HD. It took me about 2 hrs from start to finish due to trying to hold all the parts together and getting the bolts started....PITA. It would have been easier if I had a table to get the bike higher off the ground instead of my POS floor jack. :)
1 ea oil pan spacer 26146-06
1 ea baffle gasket 26147-06k
1 ea oil pick up spacer 26148-06k
You will need 17 bolts and washer that are 25 mm longer then stock, and I reused my stock pan gasket with no problems.
Danno be glad I didn't have this installed at KC. :)
Greg/Moderator
Gdub said:
Are you saying that an oil pan spacer gave you three more horsepower?
A little over 3 HP because it gets the crank out of the oil. With less holes in the back of bottom gasket it keeps oil out of the trans during a launch too.
Moderator
You SIR are correct !!!
Cool. I was not debating, I just had no idea the theory behind it. Thanks for the info.
Friend of Max.
Couldn't you just run it without oil and have the same effect? :stilpoke:
I'm KIDDING, GREG.
would this be the same thing as the zippers oil pan spacer kit? How much did it cost total? you did not re-tune it did you since the this should have no effect on the motor, only putting more power to the ground?
Greg/Moderator
I don't know anything about Zippers spacers. About $350.00 according ZANOTTI'S web site. No I didn't have it re-turned and the A&F looked good. Yes more Hp to the ground. :)
SOLD
Good info Greg, I was thinking about doing this with the kit that Zippers sells. Might just go the same way you did.
Jeff/Modistrator
Thats a cool little tip for a few added HP. How did this affect your ground clearance Greg? I wouldnt mind doing this, but there are a couple of huge speed bumps at the hospital where I work. I would hate to come to a sudden stop due to the oil pan catching on it, LOL. Yes, they are monster speed bumps!
Just for reference:
26146-06 SPACER, OIL PAN, DK PLATINUM Retail Price:$320.95
Our Price:$256.76
26147-06K GASKET, BAFFLE PLATE Retail Price:$56.55
Our Price:$45.24
26148-06K SPACER, OIL PICK UP ASSY Retail Price:$85.95
Our Price:$68.76
$370.76 Plus bolts.
Gone
Gdub said:
Just for reference:
Our Price:$256.76
Our Price:$45.24
Our Price:$68.76
$370.76 Plus bolts.
Maybe I'll just lose some weight!!!!!!
Greg/Moderator
Discussion Starter · #15 ·
This setup and speed bumbs are not a good mix.
I can't argue with the benefit from keeping the oil from pooling in the transmission but doesn't the stock setup already have a baffle plate that keeps the crank out of the oil? Or does this setup move the stock baffle plate lower?
Greg/Moderator
Discussion Starter · #17 ·
This may help
VrodG said:
This may help
Greg,
Thanks. That does help. From the drawing you posted the stock baffle remains where it normally sits so the benefit must be from keeping the oil out of the transmission.
Greg/Moderator
Discussion Starter · #19 ·
stever975 said:
Greg,
You have to drain about 2qts of oil to pull either side cover off with out making a mess. This means these 2 qt above the top gasket. So lowering the oil level 25 mm along the lower gasket not having holes in the rear is where you pick up the extra HP.
OK. Now I understand.
1 - 20 of 86 Posts
