Since everyone has been such a huge help to me on this forum, I decided to try to give back by doing a how-to on my really simple garage door opener install. Hope this helps someone who doesn't want to mess with factory wiring or pay $130 for the Harley opener! (Each "step" in this tutorial is represented by a picture)
Step 1: Buy a switch from Radio Shack. There's a ton of different models, make sure you buy a "momentary switch" and pick a style that fits your bike - they're around $4.
Step 2: Open up your garage door opener and get to the circuit board.
Step 3: Solder a 22 gauge wire on to the contact points for the button that opens your garage door. Then drill small outlet holes on the side of the opener unit and run the wires through there and close up the unit.
Step 4: Mount the opener on your ecm box - I used 3M velcro strips for easy removal and re-attachment.
Step 5: Run the wires you soldered to a convenient location. I have a 2006 D and it fit perfectly above the ignition switch. I didn't even need any adhesive or silicone, but you may need some depending on where you decide to put it. Some of the switches have mounting screws so you can drill a hole if you want.
Step 6: Clean up the wires and zip tie the loose ends.
Step 7: Tape up the switch end and mount wherever you want. Again, mine fit perfect above the ignition switch.
That's it! For about $10 in parts and an hour of time you're all set with an easily removable garage door opener you can take out at any time if you decide you don't want it.
