1 - 20 of 27 Posts
Hi everyone,
A quick thread to know if any of you knows where I can buy a Danmoto exhaust ? I live in France and I just can't find anything (even Ebay).
Thanks in advance.
As far as i know they are discontinued and unavailable anymore. I could be wrong, but that's what I remember seeing on some FB pages a while back.
No problem, i was wanting to find one myself to run just to try! i have the bassani 2-1 on my drag bike, and i was wanting to play around with some of the cheaper systems to see if there was much difference power wise
Discussion Starter #5
Apparently it is not really plug and play for our Street Rod unfortunately. Anyway, it is unavaible everywhere so that's that.
What other small and affordable exhaust is on the market for our VRSCR ?
VRSC est -03
Discussion Starter #7
Thanks. This one is too big unfortunately. I will maybe settle with just some mufflers in replacement of the stock ones.
Quick question, what is the axe diameter of the rear wheel of a VRSCR ? Seems bigger than 20mm.
Hi everyone,
Thanks in advance.
It would appear that they were bought by LCI Parts Japan and they no longer make them for Harley’s.
I’m running that one on my R and love it.
Discussion Starter #18
Hi, I put the two mufflers on.
606743
606744
My question, can I remove the black frame that used to be there to fix the stock exhaust ? Could I be able afterward to fix the whole exhaust to the grey frame without the black frame ?
Picture below to show you what I am talking about.
606745
606746
Thanks!
I did, I just made a small bracket to replace it. If I remember right that provides some support of the aux volume to the frame.
FYI, if I remember right I did have to use a small spacer with the triangle bracket I made as the mounting points are a little offset from each other.
1 - 20 of 27 Posts
