Hey Guys,
I'm having a lot of problems getting this kit to fit correctly on my 2008 VRSCAW and was just kind of curious to see if I'm the only one. Just a couple of the problems I'm facing are...
The tops of my bags lean way out from the bike unless I space the top mounts inward with lots of fender washers.
The left bag sits lower than the right bag to the point that the lid contacts the left shock.
With that bags mounted, I can put the front bail bolts in, but can't adjust the rear mounts far enough to line up with the holes.
...and yes, I DO have the left and right bars on the correct sides.
So, if you HAVE had any of these problems, I'd be curious to know what you did to correct them.
Thanks,
Russ
Thanks,
Russ
