I have a new fiberglass fender that needs to be trimed up alittle. what is the best tool to use? Also once its trimmed what's the best way to smooth it up. sandpaper. what grit?
Use a cutoff wheel. Get an assortmenn of sandpaper and start with 6 to 800 for starters. Get finer until it is as smooth as you want it.
MODOHOLIC ANONYMOUS
cut to the outside of your mark and mark the line with masking tape. this will reduce chipping/splitting. if you'll cut past the line and sand back to the line you will stand less of a chance of a fock up... don't ask how i know..
