Saw a thread here at one point that was discussing the fact that the stock map was set at 76 cu in, higher than actual.... Sound familiar? What was the conclusion - or was I mistaken?
My local Stealership is totally inept - had a SERT installed this spring and now my bike runs like shit. Will be doing adjustments myself now..
Thanks
Thanks
I know with an RT you can set the ecm to think it is a 76ci engine and it will richen it up just a little I think.
Thanks Max, I thought I saw a post that said it was set that way from the factory - trying to gather as much info as I can..
SNAFU
No, it's not that way from the factory.
WHATEVER
I and a couple other guys have done this. For me it helps when I max out the VE tables in 69 CI, just gives more latitude. You can also change the injector size in the ecm to get a longer pulse width but be very cautious and be damn sure you know what you are doing.
