1 - 9 of 9 Posts
gtrwagner
Anyone out there no how to get off peg front peg mounts which have the crash bar mounts installed over the peg mounts. It looks like the peg mounts have a set screw which I cant get to because of the crash bar mounts being in the way? I'm taking off the crash bars
Killer Service Inc.
2 bolts to remove the crash bar...
one at the top and one at the pegs...
i would put them back on...imo
gtrwagner
Ok I will try this again. I want to remove the crash bar mounts from the foot peg mounts and cant get to the set screw for the foot peg mounts the way the crash bars mounts slide over top of the factory foot peg mount to the frame ???
Killer Service Inc.
ok then lets try this again...2 bolts on my 03 hold the bars on per side.
Even where the bars are attached down at the foot peg has a flat side to it to get to the bolt that holds the footpeg in.
I can get to mine either way.
take some pics and post them maybe you have something different.
gtrwagner
Discussion Starter #5
Rsc Thanks. maybe this photo will help describing what I'm trying to remove. the crash bars are off and i'm now trying to get these crash bar mounts off??????
Killer Service Inc.
at the top of the mount is a hole. the hole might have a black cap in it.
There is a screw in there that needs to be removed.
Loosen and pull the screw out and then the rest of the assembly will slide out.
gtrwagner
Discussion Starter #8
Thanks to all out there. Yeah I got then dam things off. Just a little scare to F something up as a new owner.
Killer Service Inc.
glad you got it...
1 - 9 of 9 Posts
