1 - 2 of 2 Posts
Hi I would like To consult
i have a problem with the water pump that leaking, may it be a thermostat issue or in the gasket?
Before I open the pump, maybe someone had this issue and can help
Thanks
Thanks
I take it that it is leaking from the small weep hole in the casing? Won't be thermostat, It's usually water pump gasket problem as they corrode. Here is a good thread for you to read.
1 - 2 of 2 Posts
