An auto-ruiner? Hope not...
Agree with those above. Decel pop'ing can occur at both an overly RICH or overly LEAN condition.
Cold Air = More O2 = Lean = add decel fuel
Hot Air = Less O2 = Rich = subtract decel fuel
Obviously intake or exhaust leaks can contribute to this. Shooting carb cleaner (standard accelerant) around the bottom of the throttle body, intake boots and junction where the boots meet the head and throttle body will expose intake leaks.
Checking (re-checking) flange tightness and squareness and all connections (rear pipe to collector, mufflers to collector) will eliminate the possibility of exhaust leaks. Look for black soot at pipe junctions and around exhaust flanges. Also, if you've had your exhaust on & off a few times, you may have mung'd up the exhaust gaskets in the exhaust port on the head. I'm about due to replace mine the next time my header pipes come off again (in a few weeks for a warranty replacement of my front pipe/collector assembly due to heat shield mount brackets breaking off).
In SERT (or in my case SEPST) it's suggest to add decel fuel in small steps - if pop stops, that's it - if not subtract decel fuel. Like with carb'd bikes, the OPTIMUM SETTING is mid-way between where pop'ing STARTS both rich and lean. This of course is dependent on AMBIENT TEMPS when you're tuning. If your tune is done at AVERAGE TEMP for your location, and is dead on - it should compensate adequately for variations of ambient temps in either direction.
Best of luck...
Rick
