List of all v-rod fault codes
RANKING DTC STATUS FAULT CONDITION SOLUTION
1 P0605 Current ECM flash error 4.29 DTC P0603, P0605
2 P0605 Historic ECM flash error 4.29 DTC P0603, P0605
3 P0603 Current ECM EEPROM error 4.29 DTC P0603, P0605
4 P0603 Historic ECM EEPROM error 4.29 DTC P0603, P0605
5 U1300 Current ECM serial data low 4.12 STARTS, THEN STALLS
6 U1301 Current ECM serial data open/high 4.12 STARTS, THEN STALLS
7 U1300 Current TSSM serial data low 4.12 STARTS, THEN STALLS
8 U1301 Current TSSM serial data open/high 4.12 STARTS, THEN STALLS
9 U1300 Current IM serial data low 4.12 STARTS, THEN STALLS
10 U1301 Current IM serial data open/high 4.12 STARTS, THEN STALLS
11 U1064 Current Loss of TSM/TSSM serial data-at ECM 4.32 DTC U1064, U1255
12 U1016 Current Loss of all ECM serial data-at TSSM 3.19 DTC U1016
13 U1096 Current Loss of IM serial data-at TSSM 3.20 DTC U1096, U1255
14 U1255 Current Missing response-at TSSM 4.32 DTC U1064, U1255
15 U1064 Current Loss of TSM/TSSM serial data-at IM 2.15 DTC U1064, U1255
16 U1016 Current Loss of all ECM serial data-at IM 2.14 DTC U1016
17 U1255 Current Missing response-at IM 4.33 DTC U1096, U1255
18 P1003 Current System relay contacts open 4.14 SYSTEM RELAY CHECK
19 P1002 Current System relay coil high/shorted 4.14 SYSTEM RELAY CHECK
20 P1001 Current System relay coil open/low 4.14 SYSTEM RELAY CHECK
21 P1004 Current System relay contacts closed 4.14 SYSTEM RELAY CHECK
22 P1009 Current Incorrect password 4.30 DTC P1 009, P1010
23 P1010 Current Missing password 4.30 DTC P1 009, P1010
24 P0373 Current CKP sensor intermittent 4.25 DTC P0373, P0374
25 P0374 Current CKP sensor synch error 4.25 DTC P0373, P0374
26 P0122 Current TP sensor open/low 4.23 DTC P0122, P0123
27 P0123 Current TP sensor high 4.23 DTC P01 22, P0123
28 P0107 Current MAP sensor open/low 4.20 DTC P01 07, P0108
29 P0108 Current MAP sensor high 4.20 DTC P01 07, P0108
30 P0117 Current ET sensor voltage low 4.22 DTC P01 17, P0118
31 P0118 Current ET sensor open/high 4.22 DTC P01 17, P0118
32 P0112 Current IAT sensor voltage low 4.21 DTCP0112, P0113
33 P0113 Current IAT sensor open/high 4.21 DTCP0112, P0113
34 P1351 Current Front ignition coil open/low 4.31 DTC P1351, P1352, P1354, P1355
35 P1354 Current Rear ignition coil open/low 4.31 DTC P1351, P1352, P1354, P1355
36 P1352 Current Front ignition coil high/shorted 4.31 DTC P1351, P1352, P1354, P1355
37 P1355 Current Rear ignition coil high/shorted 4.31 DTC P1351, P1352, P1354, P1355
38 P1357 Current Front cylinder combustion intermittent 4.19 COMBUSTION ABSENT/INTERMITTENT
39 P1358 Current Rear cylinder combustion intermittent 4.19 COMBUSTION ABSENT/INTERMITTENT
40 P0261 Current Front injector open/low 4.24 DTC P0261 , P0262, P0263, P0264
41 P0263 Current Rear injector open/low 4.24 DTC P0261 , P0262, P0263, P0264
42 P0262 Current Front injector high 4.24 DTC P0261, P0262, P0263, P0264
43 P0264 Current Rear injector high 4.24 DTC P0261 , P0262, P0263, P0264
44 P0562 Current Battery voltage low 4.28 DTC P0562, P0563
45 P0563 Current Battery voltage high 4.28 DTC P0562, P0563
46 P0501 Current VSS sensor low 4.27 DTC P0501 , P0502
47 P0502 Current VSS sensor high 4.27 DTC P0501 , P0502
48 P1651 Current Check engine light open/low 4.6 IM SELF DIAGNOSTICS
