Hey guys,
I have fitted a SERF to match my VMOD pipes, and it gives me an engine light. The codes it is pulling is:
40 P0261 Current Front injector open/low 4.24 DTC P0261 , P0262, P0263, P0264
41 P0263 Current Rear injector open/low 4.24 DTC P0261 , P0262, P0263, P0264
any ideas?
Cheers,
Batts
What is a SERF?
Please limit your problem to a single post, it makes it easier to track.
In your other thread I see you have the race fueler, double check all your connections.
Sorry, I was trying to post my questions in the most appropriate areas.
Connections seem good, and bike run well, however the engine light concerns me.
Cheers,
Batts
If the light is on solid then try to remove the race fueler and see if the light goes out after 5-8 seconds. If it does you have a bad fueler or hooked up incorrect.
batts said:
Thanks Max,
Ill do that tomorrow.
Cheers,
Batts
Hey I am the same :) What you can do today do it rather tomorrow!
It ended up being the WRONG race fueler from HD. The sold me the 05A, which fits, however it throws codes.
Ahhh, problem finally solved!!!!!!
Thanks
