1 - 11 of 11 Posts
Sharks-Parts
Greetings - I am wondering a few things about clutches and trying to help out my customers... If any member can help with answers that would be very cool..:D
2006D
1- can an extra clutch disc be added to the stock basket. meaning can you get an OEM friction and OEM steel and add it inside? would I even want to do this?
2- is the Barnett extra plate kit worth the money? and does it work better than OEM?
3- is there a reason I would not want to add a slipper clutch instead of the barnett extra plate kit?
4- if you were racing your 2006D and you needed clutches and you had a 50 shot of nitrous.... what clutches would you run????
TRANNY KILLER :)
I had a stock clutch in '04, burned it up slowly
replaced with a batrnett extra plate kit in kevlar, burned it up quickly
replaced with a slipper and started spraying nitrous, burned it up slowly
replaced it with a slipper clutch repack kit... less than 300 miles ago
so I could have tried the carbon fiber extra plate kit from barnett but never pulled the trigger, it would be a better material than the stock or kevlar for racers, but for me a slipper is a great clutch, they sorta ramp up and grab even more with rpm's so I'm sold on the slipper
all or nothing
I'm now building 4th different cluch and I would say:
1. No space
2. Better yes, but not worth of money and labor.
3. No, slipper is confortable to use and stands 10..20Nm more torque (same oil).
4. No idea
Sharks-Parts
Discussion Starter #4
1. No space
4. No idea
whataya mean No idea........ come on......:D
Sharks-Parts
Discussion Starter #5
thanks bro... sounds like the slipper clutch is your choice...are you using a 50 shot?
TRANNY KILLER :)
yes, but on the last check the dyno only rang up an extra 38HP form the 50HP nozzles :mad:
JeffC 1/2 to 300mph!
The Barnett was definately a little worse to be stuck in a traffic jam with and you can't always find neutral too easy, lasted about a year on the turbo bike.
Slipper is now 3 years old and still going.
brett
yeah but i hear it that u ride it like an old fart :hidesbeh:
Killer Service Inc.
slipper...and be done with it, 200.00
tripping over dollars to save a penny.
burned up stock... plates blue
Barnett is a pain in the a$$ Like Jeff said.
but if you want I have a barnett for sale...lol
unfortunatley- the dang thing keeps doing burnouts- not me the bike.
Yeah, I slowed down but the bike keeps marking it's territory :D.
Those rear tires keep wearing out in the center for some reason.
Really tho- a 300 rear with the turbo and that clutch has done well.
1 - 11 of 11 Posts
