I have an '07 DX and I just got to thinking about something. The clutch master cylinder on '06 and older rods are different than the '07 models. Is there a difference in the clutches that would require a bigger master cylinder on the '07 as compaired to the '06's? Or, was it done just to make it look better than having the brake master cylinder one size and the clutch master another size?
Discussion Starter · #2 ·
does no one have an answer for me?
The only change I can think of is the switch to Brembo brakes. These use a different master cylinder. I suspect the clutch MC was changed to match.
I wasn't aware the 07 clutch master was bigger? I thought all the brembo's were the same size? The early model before brembo actually is bigger but to answer your question about clutch there is no difference in the slave or clutch on any year until 08.
ok, well that answers the question. It was only a cosmetic change to the clutch. Thanks guys.
