1 - 13 of 13 Posts
took my destroyer to the track last friday. ( first time out with this one.) i have owned three. the bike wants to creep ahead when i am in to the two step. my 60' time is off 3 tenths, and it does not want to down shift after the pass. it has 3 red and 2 medium springs. any ideas?
Noel
Do you know is the flake is set up total stock, arm springs and number of washers?
lighter springs and heavy arm weight might be causing premature action at your desired launch RPM????
i took the flake out and it had 3 washers on only one side. i changed to 1 washer on each side. i do not know about the springs.
Noel
That's not much weight unless they reduced it to 3 because they installed the very light springs in the flake, if you have the clutch tuners kit which has a variety of small springs, check out the setup manual for confirming & possibly resetting it back to stock.
Discussion Starter #5
i willtry this tomarrow night. thanks for the help.
You need to shift the bike into neutral and release the clutch after your burnout. When you pull in the clutch after a burn out the clutch release mechanism will not extend out to its full potential. I had this same problem. Added the neutral step to my staging routine and problem went away.
Doing this should at least resolve the "creeping ahead" while on the launch box.
Noel
That's something I had never tried, gonna try it too, once I get my engine back together :notworth:
Had a similar problem with a new (tall) clutch pack and heavy springs. By the time I got the springs and shims down to a good launch the creep went away. My flake is stock with 6 weights on each arm. Is the bike bogging at the hit? Also how much lever between clutch pulled all the way in to the bar and the 1st point of clutch engagement?
Discussion Starter #11
i guess i don't know what clutch pack is installed. i just assumed it was stock harley. that is all i have ever run. bike does not bog. if anything, it must be slipping according to my 60' time. only about an inch before engagement.
Noel
Jerry, reviving old discussion we had on this issue, what has changed since this time with your recent problem?
1 - 13 of 13 Posts
