1 - 14 of 14 Posts
Hi, I bought a 37938-08ka slipper clutch kit for my vrsca -04. Am I supposed to change the clutch fluid to DOT 4 as opposed to the DOT 5 when stock?
- it has been on shelf for years, should I dissasembly and soak in oil again?
sorry if it has been up before, couldn’t find the info
Thank you :)
VRSC est -03
Hei.
Det er ingen grunn til å bytte over til dot4. Du skal fortsette med dot5. Når det gjelder clutchpakken ville jeg nok kanskje demontert den og lagt lamellene i oljebad.
Hei.
I am sure this must translate as
The fluid is for the hydraulics and has no bearing on the clutch type. If your master cyl and slave cyl are still the 04 ones then stick to DOT5 :)
(for the benefit of us English speaking) No offense meant Knut :)
Yes, and he also said that he would probably disassembly the clutch pack and soak the discs in new oil again. Thanks for clarifying Coastrider ??
VRSC est -03
Spot on guys.
(y)
Another question - whats the torque spec for the clutch hub nut? The 30mm one.
Yes I did buy the manual but the delivery time is 4 weeks and I can’t wait that long :)
Clutch Hub Nut Torque is 220Nm or 162 ft lbs.
Don't forget do NOT let the engine rotate clockwise!! :)
Discussion Starter · #10 · (Edited)
Thanks brother, appreciate it alot. Haven’t bought the clutch holding tool so I assume it Will be challenging to hold it by hand with an electric impact wrench but I figured ill try as people manage it without. How many degrees would be acceptable without Messing with the cam timing?
Thanks brother, appreciate it alot. Haven’t bought the clutch holding tool so I assume it Will be challenging to hold it by hand with an electric impact wrench but I figured ill try some people manage it without. How many degrees would be acceptable without Messing with the cam timing?
You don't really want it turning that way at all as it pushes the chain back against the tensioners and creates slack the other side which can let the cams sprockets jump in the chain. Also you really don't want to be using an impact wrench for tightening it. Should be done with a hand torque wrench. You will probably hold it by putting it in gear and getting somebody to stand on the rear brake.
Discussion Starter · #12 ·
I’ll use that advice of yours and not go with the impact. Respect for teaching a fellow. I owe you one. ??
The Hawk
Some folks get an assistant to sit on the bike and hold the rear brake with the transmission in first gear while the clutch nut is tightened. Works pretty well.
Sent from my iPad using Tapatalk
1 - 14 of 14 Posts
