1 - 2 of 2 Posts
03 with new se slipper clutch can bleed clutch and it runs great for a few miles then starts to slip again could this be the clutch master cylinder need rebuilt you can hear sucking sound when you pull clutch lever
Check small hole in the bottom of the reservoir is not blocked, fluid level is not too high or pipe is not kinked or pinched or touching exhaust. All possible causes.
1 - 2 of 2 Posts
