What are the differences in the kits 46545-02A and 45787-06A? Are the degrees of rake different? I have read opposing accounts of what the differences really are. Will the latter fit an '05 A model? Is the 46545-02A discontinued altogether? Any help appreciated.
Also, the service manual calls for changing the bearings/races as a set if any individual component needs changed. I'm sure alot of their approach is "cover your ass," so someone doesn't put a new bearing on a beat, worn out race. However, this bike has only 5K on the clock, and I had the front end apart to check the bearing grease (which there was hardly any from the factory) and install progressive springs and chrome lowers at 1000 miles. I can't see needing to replace any bearing components EXCEPT the lower bearing and the seals and locking tab. The upper bearing/race should be fine and a new lower bearing should mate fine to a barely ridden lower race. Any thoughts?
