1 - 9 of 9 Posts
Can someone help me out? I have an 06A and was thinking of swapping out the 2 reservoirs on the handlebars to Chrome. Looks like they changed the kits over at this same year and the price is double. Can someone tell me why the huge difference in price and part numbers?
42100-06 $630
46112-02D $399
Is this because they went to Brembo Brakes in 06?
Thanks
Jake
ONe is for the newer brakes that you have, the brembos, you will need the more expensive one. Chicago HD has 20% off all the time.
HD does not have to justify price difference. But I believe the bore size is the only change, that and the overalll look.
without having a pre brembo MC to go through, all I can think of would be volume of fluid and size of openings to allow adequate fluid pressure to actuate the more heavy duty Brembo Calipers.
There is also a change in brake fluid type I believe which means different materials for all of the seals. The two different types of brake fluid a wholely incompatible.
the Fluids are incompatible, but the master cylinder and seals wouldn't care of you ran olive oil in it.
Midwest Pimp
Harley should be installing these under warranty....The brake fluid used on the 06 with Brembo brakes is eating the plastic and causing it to bubble...
1 - 9 of 9 Posts
