The motor mounts were a problem for the VRSC before 2005.... is this a common failure? ...
Yea,clean the belt w soap and water.Had a sound like "chirping" for a while now when the engine is on the overun,goes away If I pull the clutch in,my guess is its the belt but it looks okay and the tension is right any suggestions?
Hmmm...I have a 2006. My motor mount wasn't the problem. It was the motor mount bolts that came loose and broke.The motor mounts were a problem for the VRSC before 2005.
See these threads:
I haven’t heard of problems since the updated mount (16307-05) was released.
I wouldn't expect a 2006 to have a bad front motor mount (these were changed in 2005).Hmmm...I have a 2006. My motor mount wasn't the problem. It was the motor mount bolts that came loose and broke.
