:hmm: Once you modify the pipes you are not going to hear if there is anymore noise coming from the top side with holes drilled or topless.
So it looks like their still going topless but drilling holes into the sides of the airbox tray.
Suggestion: Look up "Outerwears" hydroscopic material. It allows air to pass through, but not water.Regarding ram air scoops.
Be careful in the rain, I am using an airbox cover with the inlets on the sides (kind of looks like a cobra head). As soon as it starts to rain my bike stutters because it is sucking in water.
Rule #4 - Don't ride in the rain. Wait a few minutes. It's goin' stop.Regarding ram air scoops.
That is a pretty innovative idea. I will check that out.Suggestion: Look up "Outerwears" hydroscopic material. It allows air to pass through, but not water.
I took out the false backing plates on the F and installed the material instead (which took a little bit of creativity). Got more airflow, and NO water ingestion into the filter area.
R.
Update:Thx Mromaus
Follow up -
I went ahead with the stage 1 upgrade - 06 D - Vmod-1, K&N & Topless. PowerVision SE Tune. Just ziptied the IAT for now.
Love it. Better sound but not nearly obnoxious level.
Butt- Dyno results - definitely snappier - Honks up in High RPM's.
Extra Throttle Body noise doesn't bother me. Sounds cool.
I Modified an extra Bottom AirBox "tray" - cut away all the extra plastic except the part holding the Air-Filter. Gonna see how "bottomless" runs.
Plan on putting a grommet in the side of the AF housing to hold the IAT inside.
Then start working on tuning out some o the Decel Popping.
Powervision was big bucks but real time display gauges are nice and I wanted a pretty idiot-proof way to flash the ECM..So far so good!
Lastly I got my eye on a same color, damaged AirBox Cover that I hope to get cheap and make custom air intake scoops on. Maybe won't get me much on that - might be cool though?
