1 - 2 of 2 Posts
· Metal Guitarist
Cheap trailer alternative.
i Know alot of sportbike riders who use this foldable trailer for two bikes .
It's $199, they also have a 1800 LB one for $399
But you need to add your own floor, most people use 3/4 4x8 sheets from Home Depot and wheel chokes.
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=90154
HEAVY DUTY 1175 LB. CAPACITY 4 FT. x 8 FT. FOLDABLE UTILITY TRAILER
LARGER PAYLOAD CAPACITY
Stow this folding trailer just about anywhere--it only takes up 2 ft. x 5 ft. 3'' of floorspace! Steel frame has built-in slots for stake siding (stake sides and trailer contents not included). Add your own plywood decking for a 4 ft. x 8 ft. bed. Bed tilts all the way to the ground for easy loading. Easy assembly.
DOT certified tail light, fenders and safety wiring harness
Heavy duty steel construction with baked enamel finish
Includes coupler assembly with safety chains and 1-7/8'' ball hitch receiver
Three leaf spring suspension
4.80''-12 tires
Max. load capacity: 1175 lbs; Axle thickness: 5mmOverall dimensions: 140''L x 61-1/2''W x 19-1/4''H; Weight: 287 lbs.
· Metal Guitarist
Discussion Starter · #2 ·
Here is the bigger one. $399
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=40597
1800 LB. CAPACITY SUPER HEAVY DUTY 4 X 8 UTILITY TRAILER
This workhorse has 3 leaf spring/side suspension for a quiet ride. Heavy 11-gauge steel for a lifetime of service. Comes with large red stop/turn signals and wiring harness. Also includes safety chain and 2'' coupler. Add your own planks for a durable wood bed. Bed tilts to the ground for easy loading and unloading of rider mowers, ATVs, and more.
Load capacity: 1800 lbs.
Overall length: 11-1/2 feet
Overall width: 5-1/2 feet
Tire size: 12'' rim DOT certified 5 lug
1 - 2 of 2 Posts
