1 - 10 of 10 Posts
brett
stupid question number 87 ,im changing my hand grips ,pulled the throttle side apart turned the yellow bit with screw drivere ,but cant work out what to do after that,i know what needs to be done just cant work out how to do it,do i get some pliers and give the cable a good pull and drag it over the guide or should it be easier than that ,also do i loosen the two steel L shaped cable things under the whole part to make it easier
VRF0RUMS ORIGINAL
Yes, lossen both cable adjusters to MAX loose. It's still a tight fit but will be possible with them loose.:D Make sure when you put it back together you leave a little slack in the throttle to get the full range of motion in the throttle (about 1/8 turn on the throttle... (free play)):D
VRF0RUMS ORIGINAL
The throttle cable (the front one) should come out without too much hassle. The idle cable (rear) might need some guidance with a small flat blade screwdriver.
bwds said:
ok ,will do that ,,once thats done,should i be able to get em out with or with out pliers??????
I did use a real small pair of needle nose pliers that had no teeth just to grab the cable and coax it into the right spot. The first one I did took me a few minutes to get it in, the second and subsequent ones were easy once I knew how to get the cable in the right spot. As stated above, loosening the adjusters all the way out is a must though..
brett
whoo hoo ..got it done was easy once loosend the adjusters,,didnt undo them at all before no wonder had trouble...only question now is what do the adjusters adjust and how do you re adjust them ,for the moment ive just put them where i think they looked like they were,,,,,thanks
Friend of Max.
The adjusters adjust the tension on the cables. You know the play in the cable before you start to move the throttle bodies?
This is the best advice I have heard on the subject. Link Here.
1 - 10 of 10 Posts
