1 - 2 of 2 Posts
Couple question:
  1. When changing out brake fluid in front calipers is it necessary to change the rear as well? Or is the brake system all linked together?
  2. How do I go about changing my trany fluid? When doing a regular oil change am I replacing fluids in both engine and trany? Or does this have to be done separately?
You should change all the brake fluid. The rear brake fluid is located behind the right side radiator cover. Also change the clutch fluid too.
The trans is located in the engine so when you change the engine oil it changes both.
1 - 2 of 2 Posts
