Does anyone have the torque spec for the figure 8 clamp and the rubber mount bolt?
My CFR has slipped off at least 3 times. It is very aggravating when you are away from tools. The only luck I have had keeping it on is to tighten the nut and then tap on the figure 8 clamp with a 16 oz hammer. The nut will then turn another 3/4 turn or so to achieve max tightness. It has only slipped off once since tapping with hammer. Good luck.GreysonWinfield said:Does anyone have the torque spec for the figure 8 clamp and the rubber mount bolt?
When I go to push for that last turn shuold I break out the BFH?Vrod-Mike said:Crank it till it won't turn anymore. :hidesbeh:
JB or conventional?DTHDOC said:weld it to the head-pipes
