1 - 10 of 10 Posts
Well, got my Chrome CFR today, and in the garage trying to install it. Well having problems removing the Aux section. This is the protion before the stock slip-on. Look in the manual and it pretty vague. Is there a trick in removing this section, so I can slip the CFR on. Thanks
Mike
btw this is an 03.
2" of dangling death
a big freaking hammer, they are a real pain in the ass
Chrome is king!!!
Mike
btw this is an 03.
It's a real PITA. I put a long prybar on it and used a BFH to pound the $hit out of it.
ok...was kind of hesitance, I'll go try it. Thanks guys.
k, got it out. That figure 8 clamp is a PITA to put over the CFR. Think I'm going to the hardware store in the AM and get one that will fit better.
BTW- Mike, did a search on CFR Install, notice you mention in buying a new clamp. Are these hard to find or can you get it at your local home store. Thanks
m
m
To re-use the figure eight clamp and make it easier to put on the cfr get a very large hose clamp and wrap it around both pipes. Tighten the clamp until the pipes pull together enough to just slide the figure eight clamp right on. :)
Chrome is king!!!
m
I said to use a new clamp because HD recommends a new one whenever the old one is removed. I think the only place you will find that clamp is at an HD dealer.
Just an update. Used Max idea and used 2 large hose clamps, tighten down enough to installed the figure 8 clamp. CFR installed and currently using Creeps download. Took her for a quick spin and (WOW!!!!) all seem good. Once again, thanks ALL!!!
Mike
WHATEVER
I have had my original clamp on and off a dozen times and it still works fine!
1 - 10 of 10 Posts
