Marine 24/7
is anyone having a problem with the end cap working it's way off on the cfr pipe? if so and you have fixed it what did you do and did it work?
Yes mine works itself off also especiall after I ground the rivit off from right turns. I just re rivited it with steel rivits but still come back about 3/16ths of an inch right where you can about see the orange gasket. the only way i see fixing it is to add a 3rd rivit right at the top . easly done with driling and riviting. I have not yet done this but might and put some black paint on the rivits.
Anyone know if bikers image and CFR is still honoring there policy on end caps that change color, i.e. if it does they hook you up with a new one?
And no, mine hasn't worked loose yet.
