Have an 09 Muscle and getting c1095 and c1216 codes brake light works and abs also works fine if I lock the brakes up. Any ideas? From what I read, could be brake light issue, ecm issue, abs issue but I am not having any probelems at all. I did install a brake light modulator so possible that is causing the codes?
Replaced the diode pack yesterday, cleared the codes, start the bike and codes back again. Weird thing is the brake light works perfectly with both controls and the abs will cycle if I lock up either the front or rear brakes and there is no trouble light illuminated on the gauge. Since everything appears to be working as it should, I am inclined just to leave it alone and keep riding. Am I missing something?
